I have problem with Reset element parameters with parameters which was changed during the work or assign in rhino.inside level by using Element Parameters.
When I’ve tried to reset element parameter which I assigned by Element Parameters I’ve received two errors:
RhinoInside.Revit.External: Object reference not set to an instance of an object.
Thank you for your answer. Now when I used Query Element Parameters component parameter is recognized but I’ve received the same error like before when I tried to reset parameter.
I think the issue is a bug, there’s something different about the shared parameter that isn’t being accounted for. If it’s an easy fix it will go into a daily build this week. We’ll post back here with more info once available.
