I have some parameters I want to add to a Revit project as type parameters. The definition is read from the shared param file ok but the “Add Parameter” component fails when the scope is set to Type or Instance. It works for Global.
Does anyone have a clue why this is happening or if I am doing something wrong?
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 8-7-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 517.02
Accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-7-2022
Driver Version: 31.0.15.1702
Z-Buffer depth: 24 bits
Total Video Memory: 10 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\ProgramData\Proving Ground\Conveyor\ProvingGround.ConveyorRhinoInside\ProvingGround.ConveyorRhinoInside.rhp “Conveyor Rhino Setup (Rhino 7)” 3.1.8.0
C:\Users\akotzambasis\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22102.1509
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino.rhp “ClimateStudioRhino” 1.5.7955.28487
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\RhinoBeat.7 (d6f60aad-2954-44ef-9054-904ca827b721)\1.1.35.0\Rhino_7\RhinoBeat.7.rhp “RhinoBeat.7” 1.1.35.0
C:\Program Files\AVAIL\AVAIL Browser for Rhino\AVAIL.RhinoPlugin.Rhino7.rhp “AVAIL.RhinoPlugin” 4.5.8.0
