Dear @dale, mostly suggested approach here for writing eto UI is in C# as far as I know. Developer samples cover also only C# (unless I missed something).
UI in eto can be written in:
One .cs file, no preview
Two files: .cs (code behind) and .eto.cs (view), giving access to preview in Visual Studio with eto extension
Two files: .xeto (xaml like view) and .xeto.cs (code behind), giving access to preview in Visual Studio with eto extension
Two files: .jeto (json like view) and .jeto.cs (code behind), giving access to preview in Visual Studio with eto extension.
From some time I have experience with WPF, and I feel writing UI in xaml is more efficient than pure C#. I know that preview for eto is not the same as for WPF, but it is still better than nothing.
Is it possible to prepare sample similar to https://github.com/mcneel/rhino-developer-samples/tree/7/rhinocommon/cs/SampleCsEto using xeto with ViewModels, Binding and ICommands (if supported by eto). I saw RhinoUI have some internal ViewModel class but I did not see anything for DelegateCommand/RelayCommand. I feel seperating those will be more MVVM like and help to create more clean and testable code.
Also there might be less questions about MVVM on forum
Trying to replace eto with xaml like Avalonia may need to reference 100mb of Avalonia dlls and I am not a fan of that.
While this is probably not exactly what you are looking for, Iâve experimented a bit with the .xeto/.cs duality and am going to share my experiences here.
Itâs very much like .xaml/.cs but youâll need to use eto components instead of wpf. So youâll be missing out on objects like <Border>
What also annoys me is that there is the full RhinoWindows Nuget package which has been recommended here on forum, but as I see much of the code is totally undocumented. Also itâs tough to know whether to use this or not since RhinoWindows is not crossplatform. Which means that those viewmodels logics should live in rhinocommon and not rhinowindows.:
There is an example of MVVM in the SDK, although this should be expanded a lot and include commands (I donât see a single ICommand instance in Rhino SDK):
The Command class does exist in Eto and is not to be confused with the Rhino.Commands.Command:
