Are you planning to stick with ETO forms or is something else going to take over?
I seem to have an easy time with XAML (aside from data binding, but still learning). Aside from that I’ve only used DCL (for AutoCAD’s AutoLISP).
I’m sure there’s a reason you chose ETO forms for Rhino 7 and prior. I haven’t found much in the way of developer resources for it. I would also only be keen on learning it if it was absolutely the form to use for Rhino and was guaranteed support well into the future. For that reason I would prefer to stick with XAML based forms (or something similar) if possible.
Note that I’ve also decided on a longer-term learning plan, meaning I’m not in a hurry to get anything working right off the bat, but rather just wanting to get familiar with everything before I actually start programming anything.
It should be noted that we are still using WPF on Windows. Eto is an abstraction on top of WPF and an abstraction on top of Cocoa on Mac. This lets us use a single codebase for developing UI.
To better explain: I am trying to get a solid handle on C# before trying to do any actual API work. I can create console programs but don’t fair too well for anything beyond that.
But it probably wouldn’t hurt to start going through the Developer Doc’s…
