Hello Rhino & Grasshopper community,
I am currently working on an design assignment called “Animated Nodes”, as you can see in this example, and I would greatly appreciate your advice, ideas, and technical guidance. The task is focused on combining parametric principles with structural logic in order to develop a parametric structural system for a sports hall.
The main goal is to create a Grasshopper script that can systematically generate different structural configurations. The definition should control at least ten meaningful parameters—such as span length, density, height, or number of nodes—that have a clear influence on both the structural logic and the overall design. To make these variations understandable, I also need to produce an animated GIF that shows how parameter changes affect the structure. This could be done by illustrating smooth transitions between design variants, animating individual parameter changes, or combining multiple transformations. The idea is that the animation communicates both the logic behind the script and the spatial qualities of the generated structure.
In addition, it requires me to develop one characteristic connection detail. This detail should be modeled constructively and accurately—optionally even parametrically—showing its materiality and connection technique. To further clarify how it is assembled, I also need to produce an isometric exploded-view animation (MP4 format or similar) that visualizes the components and their assembly sequence in a clear and understandable way.
The deliverables include the Grasshopper script itself (as a .gh file), two A3 layouts—one showing the cleaned-up script and another showing four different parameter configurations—an animated GIF of the parameter variations, and finally, the exploded-view animation of the detail.
Where I could really use help is in several areas:
Suggestions for selecting parameters that are both structurally meaningful and visually expressive
Best practices for keeping a Grasshopper definition clean and modular (I am working in Rhino 8)
Workflows for animating parameter changes and exporting them smoothly to GIF
Tips or examples on how to create exploded-view animations of connection details
Recommendations for useful plugins or workflows that might simplify these tasks (especially if they are Rhino 8 compatible)
Any insights, example files, or references you could share would be extremely helpful. Since this is for an current project, the focus is more on clarity, logic, and legibility than on overly complex solutions.
Thank you very much for your time and expertise!
Best regards,
Kate
