I’m not sure where to post a request, but I think it would be beneficial to have a new, different color automatically assigned to new layers. After 12 or so new layers are created in a project, I spend too much time trying to find a new color that I haven’t yet used. It doesn’t seem like much, but when it’s multiple projects every day, the time adds up.
This is a function in Cinema4D. The first screenshot is a single layer with a color automatically assigned. The second shows 10 layers with each color automatically assigned. I realize that the colors assigned won’t work with every custom background color, but it’s a good start instead of changing the color from black every time.
I’ve also included a screenshot of what one of my typical files might look like in the layers panel, each color manually assigned. Even if the amount of time isn’t considered because realistically assigning new layer colors in this project may have accumulated to less than 5 minutes, I think this can contribute to design fatigue, which, I’d rather reserve all my decision making to the project itself, not layer colors.
right clicking on the New Layer icon does nothing… right clicking in the layer window then selecting New Layer created a new layer, but the color is always black.
Regular Rhino is fine, there is no special wish category. I guess posting wishes in Serengeti is also fine, I just forgot to mention it right away that this was a v8 feature.
You could randomize your layer colours with a script like this:
import random
from System.Drawing import Color
def randomizer():
red = int(255*random.random())
green = int(255*random.random())
blue = int(255*random.random())
return Color.FromArgb(red,green,blue)
def RandomLayerColours():
rs.EnableRedraw(False)
layerNames = rs.LayerNames()
if layerNames:
for name in layerNames:
rs.LayerColor(name, randomizer())
rs.EnableRedraw(True)
if __name__ == "__main__":
yep but as you said only show the color after the line was drawn, so if my background is dark and I am drawing in a black layer I will have to change first the layer color . Got it thanks
If you are always working with a dark background, you might want to change the default layer colors in your templates (as well as the default new layer color in settings) to colors that suit you better.
Well, you can make all curves draw in one constant color by creating a custom display mode and setting curves to display as a single specified color. That way all your curves will be the same color (while in that display mode) no matter what layer they are on. I personally wouldn’t recommend this, but YMMV.
