I want to create a stripped down version of Rhino by removing most of the standard menu items. The goal is to have a minimum set of options left that doesn’t overwhelm users and focuses on the important bits. I researched a bit and found that this is not possible: “In the default menus, new menu items can be inserted, and these new menu items can be edited and deleted, but default menu items cannot be edited or deleted.” (Rhinoceros Help)
I also found this topic in which is explained how to hide the whole menu bar: Customize skin. Is there any chance to replace it with a completely new one?
I’m tending to hide the menu bar and use a toolbar instead. Do you think there’s a better option?
But that .RUI file will only be added to an existing menu but doesn’t create a new one, right? So I cannot provide a .RUI file and hide the menu because this will hide everything. So, as far as I understand, it’s completely impossible using only .NET.
