I’m looking for a way to replace text as shown in the image. In this case, I want to replace each “REPLACEx” with a CB/CT value. The CB/CT values are in two separate lists, and I also want to get two separate result lists, as shown in the output I wrote.
One important detail is that, for example, REPLACE13 should not be replaced by REPLACE1. Because of this, the “replace text” node doesn’t work properly. I’ve added the file — thanks in advance!
Replace text.gh (12.1 KB)
