Hi there, I’m hoping someone can help me out with something. I’ve got two sets of points and would like to reorder them so they don’t skip/jump past any points, so that when I create a line between the two points they will go to the point vertically above (which I may have to use shift list for I believe…? I’m quite new to this software and any help would be greatly appreciated, thanks!
It looks like your curves are oriented in opposite directions. Flip one of them and see if that helps. otherwise, post your file.
If your points are more or less in a circle, you can use sort along curve.
And yes, post your file with the relevant geometry internalised.
