hwansey
February 16, 2021, 1:20am
1
I am enjoying Rhino 7, especially the new in house rendering capability.
However my machine seems to really struggle with it, especially when rendering multiple layers and with blocks added.
Files that have multiple blocks in them are also a bit clunky even in shaded mode when rotating in perspective.
This is what I have:
This is what is set in cycles:
Have I set my machine to the best it will do, and is it really suitable for Rhino7?
hwansey
February 16, 2021, 6:16am
2
Added to above:
Rhino 7 SR3 2021-2-8 (Rhino 7, 7.3.21039.11202, Git hash:master @ 7bcc02a54515376cb2bd3d05f62d9473ab4bc38c)
License type: Commercial, build 2021-02-08
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 10.14.6 (Build 18G8022) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,4
Language: en-AU (MacOS default)
Intel Iris Pro OpenGL Engine (OpenGL ver:4.1 INTEL-12.10.25)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel Iris Pro
Displays: Color LCD (221dpi 2x)
Graphics processors
Intel Iris Pro (1536 MB)
Color LCD (1440 x 900)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Broadcom Corp.: Bluetooth USB Host Controller
Bluetooth devices
Broadcom: Magic Mouse 2
Third party kernel extensions
None
Third party plugins
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 7.3.21039.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 7.3.21039.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp "AnimationTools" 7.3.21039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 7.3.21039.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp "Displacement" 7.3.21039.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 7.3.21039.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp "Import_OBJ" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp "export_xaml" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp "QuadRemesh" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp "export_OBJ" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp "Export SVG" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp "Export_DAE" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp "PDF Export" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp "IGES Export Plug-in" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp "Import_SVG" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp "BlockEdit" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp "Export_AMF" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp "Import_DST" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp "PLY - Polygon File Format Export" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp "Import_AMF" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 7.3.21039.11202
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 7.3.21039.11202
nathanletwory
(Nathan 'jesterKing' Letwory)
February 16, 2021, 6:36am
3
In Rhino 7 Raytraced and Rhino Render currently don’t have GPU accelleration. This hopefully will change if and when the underlying render engine Cycles gets a Metal backend. The ETA on that is unknown. In your case it isn’t an issue anyway, since there isn’t a GPU to accellerate with.
There are some speed improvements that I am currently working. These will help to some degree on lower-power machines like yours. I also have two Mac laptops that I have to work with, and they are not a good choice for doing heavy rendering. The Mac laptops I work with already start to cry when I try to build Rhino from source. They become very heated, are very slow (compiling takes upwards of 30 minutes for even simple changes). All very frustrating. Then trying to use Raytraced and Rhino Render makes the laptops sound like they’re about to take off, so loud do the fans spin up.
I feel your pain with Raytraced and Rhino Render. I’ll be trying to make it less of a pain.
For the other display modes I’ll refer you to @jeff and @DavidEranen , but I think the verdict will be that the GPU isn’t providing enough juice to make Rhino 7 completely happy.
