For the past week, I’ve had the issue to change the rendering settings, because whenever I do it causes rhino to not respond and in turn crash. I can type render in the command bar but I can’t change the settings to the final quality or the viewport to a set resolution. I have done an uninstall and reinstall but no luck.
I’ve included what happens when I try to open a rendering tab.
Perhaps you can start by copy&pasteing the result of the Rhino command _SystemInfo, that will clue is in to possible causes.
Rhino 6 SR29 2020-8-25 (Rhino 6, 6.29.20238.11501, Git hash:master @ 06b936ae4e8c289ecccfd6b5ee9bacccc60eded1)
License type: Evaluation, build 2020-08-25
License details: Cloud Zoo. In use by: Helen Degenerate ()
Expires on: 2020-10-31
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: DESKTOP-4SE8RM1
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce RTX 2080 SUPER (NVidia) Memory: 8GB, Driver date: 7-5-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 451.67
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-5-2020
Driver Version: 27.21.14.5167
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.29.20238.11501
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Users\Julien\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.2.2.0\6\Fologram.IO.Rhino3d.Win.rhp “Fologram for Rhino” 2020.2.2.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.29.20238.11501
C:\Users\Julien\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.29.20238.11501
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.29.20238.11501
C:\ProgramData\McNeel\Rhinoceros\6.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\Julien\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2019.7.29.584\SectionTools.rhp “SectionTools”
Can you try disabling all plug-ins that do not ship with Rhino through the plug-in manager? Tools > Options > Plug-Ins, set filter to plug-ins that do not ship with Rhino, right-click and enable load-protection. Once done restart Rhino and see if it works any better.
Unfortunately, that didn’t work, is there anything else I could try?
If you double-checked that Fologram and Twinmotion weren’t loaded at all then I have currently no idea what could be going on.
