Rendering Question
Hello all,
Just a rendering question for Rhino for Mac WIP 7. All of my objects in this drawing are on separate layers. However, when I go to render the tubes and some of the walls get grouped with the same render material. Here is a screen shot and the file. Any ideas why this might be happening?
Thanks,
RickScreen Shot 2020-02-12 at 10.17.24 PM.pdf (723.0 KB) Jos bathroom Asteras.3dm (8.0 MB)
They may be created on separate layers, but the objects all have the same render material applied. You need to apply some different material to objects you want to have with a different color in Rendered mode.
Thanks for responding Nathan!
I did give every object its own material and thats what makes it so strange?
Best,
Rick
Hi Richard - it’s one way of assigning materials to objects.
It sounds like you are expecting the objects to use a material that’s assigned to a layer - in which case you need to set the object’s material assignment as such:
Thanks Wim!
That did it!
Cheers,
Rick
