Hi, I’m new to the forum. I was wondering if it is possible to render the “wireframe” of an image with the background set to transparent. Is this possible in the stock Rhino 5.1 for mac? Without any plugins? Would be greta to know this procedure.
I have tried the “Make 2-D drawing” but it just sits there, and you can’t select anything.
For this, you can maybe use the ViewCaptureToFile or ViewCaptureToClipboard commands.
These you can use to get a capture with configurable height/width. Use the scripted version by adding a - (dash) in front of the command, to get to the options.
