Hi @taraskydon,
I believe this slider controls this:
https://developer.rhino3d.com/api/rhinocommon/rhino.render.linearworkflow/postprocessgamma
ā Dale
Indeed, doc.RenderSettings.LinearWorkflow gives you access to that info.
Here is the working method I use. thanks for the tip.
public static void SetParameterGamma(bool on, float gamma)
var rs = RhinoDoc.ActiveDoc.RenderSettings;
rs.LinearWorkflow.PostProcessGammaOn = true;
rs.LinearWorkflow.PostProcessGamma = gamma;
RhinoDoc.ActiveDoc.RenderSettings = rs;
Indeed that is how it is done.
For the reader in the future stumbling on this: It is required to first get the RenderSettings object, make changes, and then set it back to the RhinoDoc.RenderSettings property. Trying to setting directly say like doc.RenderSettings.LinearWorkflow.PostProcessGamnmaOn = true; does not work. It is setting the property on the document that actually will trigger the change properly.
