Change gamma from python
Hello!
How can I change material’s gamma from python script?
Thank you!
@andy, @nathanletwory - is this something you can help with?
You can change parameters on RenderContent using the GetParameter() and SetParameter() API. This works for RenderMaterial, RenderTexture and RenderEnvironment.
To find out what the parameter name is you do that easiest by saving your (top) render content as a file. Simplest is by dragging the material or environment to the Windows file explorer. Then open the resulting .rtml file in your favourite text editor and search for the parameter name. If you have a hard time guessing what the name could be just set a special value you can search for, say 99.99. Do the search and take note of the parameter name.
variant = rc.GetParameter(yourparameternamehere)
print(variant.ToDouble(None)) # or ToBoolean, ToSingle, ToUInt64 etc. use dir(variant) to find out what the possibilities are
To change:
rc.BeginChange(Rhino.Render.RenderContent.ChangeContexts.Program)
rc.SetParameter(parametername, 4.4)
rc.EndChange()
Here a short video if the text alone wasn’t clear enough
Thank you!
If you want to change the gamma value of bump/normal map for all PBR materials, the script compiler will give an error prompt:
Message: ‘PhysicallyBasedMaterial’ object has no attribute ‘GetTextyreFromUsage’
what shall I do?
Thanks
Hi @Alen_Russ, this should be spelled GetTextureFromUsage i guess.
_
c.
hi,
this is the python code from nathanletwory, i dont know how to do for this
import Rhino.Render as rr
import scriptcontext as sc
for rm in sc.doc.RenderMaterials:
    #rt = rm.GetTextyreFromUsage(rr.RenderMaterial.StandardChildSlots.Diffuse)
    rt = rm.GetTextyreFromUsage(rr.PhysicallyBasedMaterial.ParametersNames)
    variant = rt.GetParameter("rdk-texture-adjust-gamma")
    rt.BeginChange(rr.RenderContent.ChangeContexts.Program)
    rt.SetParameter("rdk-texture-adjust-gamma", 2.2)
    rt.EndChane()
It’s RenderMaterial.GetTextureFromUsage.
– Dale
Hi @Alen_Russ, there are some more typographic errors, please try below:
    rt = rm.GetTextureFromUsage(rr.PhysicallyBasedMaterial.ParametersNames)
    rt.EndChange()
_
c.
hi clement,
i have tested your code, it show this
Message: expected StandardChildSlots, got type
Traceback:
  line 5, in <module>,
Hi @Alen_Russ, the original code is not by be, below seems to work and changes gamma to 2.2 for diffuse channel texture.
    slot = rr.RenderMaterial.StandardChildSlots.Diffuse
    rt = rm.GetTextureFromUsage(slot)
    if not rt: continue
    rt.EndChange()
_
c.
thank you. it works well
