Removing specific character from texts and then raising them to Z value
I recently received a dwg file with the points for the contour but they all have a + before the number, is there a way to remove the “+” from the text and then raising them to the correct height in order to make the topography? Thanks
pts.3dm (166.3 KB)
I guess you can do something like this, don’t need to remove the +
but take care of double checking the units of your drawing, because it looks like the distance between points is MUCH HIGHER than the delta height (distance between points is in the order of thousands units, vertical movement in the order of dozens units)
pts.gh (8.5 KB)
thank you, ill give it a try
