Remove the "Apply" button in the "Modify with a box"
Would it be possible to remove the “Apply” button in the “Modify with a box” interface panel so that changes in size, position, scale, rotation values ​​according to x y or z are taken into account in real time
This problem has been described several times but there seems to be no solution as there have been misunderstandings. I have the same problem and would like a solution. In windows you can enter values in “box edit”, press enter and that’s it. Unfortunately this does not work under OSX. You have to press the “apply” button every time to confirm the values. Otherwise they jump back the next time you click in the UI. This is annoying and takes time. It would be nice if you could confirm with enter or right-click under OSX, or even change the values without confirmation in both operating systems.
Do we have any updates on this?
i believe nobody is going to work on that any time soon. just another fancy fish that was left in shallow waters to die.
I’ve put that issue on the list as RH-91442 BoxEdit: Apply with Enter
hi Wim, just in case i made a topic about this 5ish years ago. @stevebaer and Pascal were talking about some tracker that was not published, there ought to be a different tracker then i assume.
How about a “tracker-tracker”? And a “tracker-tracker-tracker”?
lets be frank here. the only thing that’ll ever work is a tracker for the trackertrackertracker
