when several object groups are grouped within another group, how can I get the group out of there without ungrouping everything, or selecting all geometry one by one?
I would love to have a command: “remove group from group”
hmmm- That seems like a hard one to solve since objects can be members of any number of groups.I don’t know how to get there cleanly without using names.
yes, Holo that works but not if you have groups in groups in groups.
so if I have to ungroup+ungroup to get to ctrl+deselect the goup I want to extract, then the grouping of other groups is lost.
oh boy… a lot of grouping going on there, but after all it makes sense I hope…
so what Iwould like to have is basically a selection list of groups within which a piece of geometry is contained and then extract the respective parts by choosing a group
Hi Daniel,
If you don’t Name or Label your groups, how do you know what’s in a group and what groups are in a ‘group of groups’?
Sounds like you might benefit from setting up a ‘naming scheme’.
Use SetGroupName and within that Command, '_SelGroup.
List to choose from:
Select and name something meaningful…
I have been using a script I wrote just to handle cases like you have described (to extract a group from a hierarchy of groups). It is a bit tricky as Pascal said since Rhino allows for groups cross-referencing objects. So you need to be a bit careful with that.
The script is smart enough that if you try to externalize a group that has sub-groups, it will keep them intact, unless some of the objects are cross-referenced into any groups with objects not belonging to the group you are externalizing (are you still following? )
Here is the tool, save on HD, drag-and-drop into Rhino; the command is: Externalize_Group
cross referencing not an issue in my files… I use this grouping as a quick on the fly, while drafting replacement for blocks. A pure graphical way of quickly organizing a file. And in this course I sometimes encountered the urgent need of doing exactly what your script can do.
I was pretty sure someone else was bugged by this, too.
thanks for sharing!
great, I’m glad it helps!
I try not to rely on nested groups too much due to lack of clarity in viewing the hierarchy, but definitely sometimes grabbing a nested group from more complex grouping is a big time saver…Also some imported files like SKP create bunch of nested groups on import, so that’s another case when I use it.
in Rhino v2 there was a plugin that would list group names and I believe hierarchies as well in a layer-type always on window. would be happy to see that resurrect
