Hello everyone,
i have a question about the relationship between the mesh and the surface loads in the exact mesh load const.
Via Karamba 3D Chapter 3.2.1: The mesh where the load is applied and the underlying structure do not need to be connected. It needs to be fed into the “Mesh”-input-plug.
Does this mean that the mesh of the surface and the mesh of the load must perfectly match or will the load be assigned to the closest surface mesh nodes in case of mesh-differences?
Thank you very much!
Kind Regards
Patryk
