Hi @eirannejad and @Alain,
I thought I’d just expand on an issue with the text/legibility of the new script editor (briefly touched upon here and here) as compared to GHPython. The captures below are on a 3840x2160 external Dell monitor running at 125% scale, but the same issue is present on my laptop monitor, and while running at other scales. Specifically, when using the same font (Consolas here), the new editor will render same style text with a “thinner stroke” and looking “vertically squished” at certain sizes. It also appears to use larger line spacing, meaning we can’t fit as much code in the same vertical space. Here are three size jumps demonstrating this:
The text “stroke” in the new editor also appears to be more “jumpy” when going up/down in size, where GHPython has a more consistent/smooth looking scaling appearance:
Note that this is not an issue of the missing bold keywords also mentioned here, and that I’ve had to use different font sizes to get similarly size text between the two editors. And I understand this is probably just an issue of the new (Monaco-based?) editor, but if this is something you can tweak somehow, I’d certainly appreciate it.
Thanks and best,
Anders
Edit: Forgot my system info:
SystemInfo
Rhino 8 SR8 2024-5-28 (Rhino 8, 8.8.24149.15001, Git hash:master @ 49367284ece6544c4e32d4d2fce81c37a1bd9dff)
License type: Commercial, build 2024-05-28
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.19
Computer platform: LAPTOP - Plugged in [62% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 11-7-2023 (M-D-Y).
Primary OpenGL: NVIDIA RTX 2000 Ada Generation Laptop GPU (NVidia) Memory: 8GB, Driver date: 6-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.45
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-26-2023
Driver Version: 31.0.15.3645
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24149.15001
