RegionUnion vs createBooleanRegions vs createBooleanUnion
This topic has come up several times, but doesn’t seem to have a real solution. Is it a bug?
The attached GH file shows a set of curves in 8 branches.
For createBooleanRegions, all work.
For RegionUnion component and for createBooleanUnion, only 7 of them work, 1 doesn’t.
Document tolerance does seem to matter (reducing the number of the working ones) but even at 0 does not solve it…
Any thoughts?
Many thanks in advance.
curveBoolean_Region_Test.gh (175.6 KB)
Ah! Brilliant…
Thank you so much!
Trying with a set of slightly more complex curves, the original error came back (simplify curves doesn’t help).
Directly in Rhino (via bake, curveboolean) works. But the GH doesn’t do it for all curves. Tweaked with document tolerance to no avail.
Any thoughts?
Thank you!
CurveBooleanTest2.gh (22.7 KB)
PS: Ultimately, all that is needed is calculating the area for each of the 5 boundaries. Any other, non-curveBoolean, solution would also do.
It seems simple but I think it works.
