Reference Layers
Hi Dale,
There is a very convenient method in the RhinoDoc Layers table for adding a reference layer (AddReferenceLayer).
What is the mechanism to do the opposite to remove a reference layer. Purge does not seem to be able to remove reference layers.
Thanks, Larry
Hi @LarryL,
The short answer is no.
Reference layers are added to a Rhino document when you insert a linked block or include other models are part of a worksession. Referenced layers are never saved in the document that references them.
The Purge command ignores reference layers, as they are not saved with the document.
– Dale
