After deleting the referenced layer (and purge command). The layer is still displayed in the layer tree.
jmv.
jmv.
Hello- I just tested that here and it seemed to work as expected - does this ever work for you, even in a very simple case?
It is true that with this file I have a lot of problems with the files imported as references.
I will have a little more time this evening to test a simple case.
I find that Rhino is very inconsistent in clearing reference layers after the reference has been deleted. Purge sometimes resolves the problem but not always.
Dennis
Yes, in a simple case it works correctly.
I don’t know what is the peculiarity of my file that prevents the complete deletion after a “Purge”.
Jmv.
