Reference by Type not working for Brep and Surface in Beta
I have installed both EleFront v5.0.2-beta and eleFront-Rhino-6-Legacy and I’m using Rhino 7.
The rhino file contains1437 polysurfaces, 8 extrusions and 2078 surfaces.
However, when using Reference by Type in Beta version:
Brep, error: 1. Solution exception:Object reference not set to an instance of an object.
Surface, error: 1. Solution exception:Object reference not set to an instance of an object.
Polysurface, successfully referenced 1445 Brep
Extrusion, successfully referenced 8 Brep
Does anyone know why “Reference by Type” is not working for Brep and Surface in this case? Thank you.
Update:
I used the R6 legacy version and the issue is resolved. The issue seemed to be bugs in Beta version only.
Hi, do you possibly have a file to share? I’m not able to recreate the issue on my side, the component seems to be working as expected.
