Could anyone help me to solve my issue?
There has been this types of question in this forums but I couldn’t find my case.
My issue:
Error message: Object reference not set to an instance of an object
When I wanted to trim curves with a brep (breps) component, this error has appeared
The curves did’t cut as below image:
@HS_Kim except you opened in Rhino 6, and I see the user asks about Rhino 5 (at least thread is tagged with that). Probably a bug that got fixed between the two releases.
Thanks for quick reply.
It is very strange. I tested my script with two different computers.
I had a same error message from them.
Are you using Rhino 6?
I am using Rhino 5.
