I tried to simplify the problem that I am facing. For the calculation of my python script I need the output of the python script. I thought I could handle this by scripting like this:
if x == None:
x =1
a = x+1
But no, I get following error message : Recursive data stream found, this component depends on itself. What this error message is saying is clear, will there be any way around for this?
Simply write a recursive function inside your Python component! A recursive function is able to call itself until a condition is met.
Example:
def do_something(x):
if x > 3:
return x
else:
x += 1
do_something(x)
As long as x is smaller than 3, the function do_something adds 1 to x and calls itself with the updated x-value. Starting at 0, the function is going to run recursively 3 times until it returns x (with a value of 3).
