Recompute solution is broken in Rhino 8.5?
Hi All.
I noticed this problem in Rhino 8.5
If I change the original geometry from Rhino, Grasshopper in this version does not update Solution as it did in all previous versions.
For example, if I use a curve as the initial object and then modify it, the geometry in Grasshopper does not change until I press F5 (Recompute).
This did not happen before. And I certainly did not change anything in the settings. I wonder if it’s just me, or if everyone has this problem?
Thank you.
I’ll need to test this tomorrow when I get back to the office.
Hi Dmitry,
I’m not seeing this in 8.5.24046.03001, can you post your Rhino SystemInfo & a small example of what is not working for you?
That’s how it works
Sent you the latest build.
If this doesn’t do it please disable the Keyshot and try again.
If that doesn’t do it lets restart Rhino and initiate GrasshopperLoadOneByOne and say no to grasshopper plugins that do not ship with Rhino.
You know, I’ve just installed the latest build and tried it without any other changes and the problem is disappeared! Thank you so much! :grinning:
