Hello all, apologies if this has been covered before but I’ve been trying to find a way to call previous commands from the command line. Similar to the up arrow in ACad or typical command line interfaces.
I know the middle mouse button pop-up can show this list but would like to have it available through keyboard input, is there a way to map this via alias, script or other method?
You can righ-click on the command line for the popup list of recently used command.
The command is "_PopupMenu", it can be assigned to an alias or keyboard shortcut.
Technically once you have the popup menu, you can use up/down arrow keys to navigate it and Enter to make a selection. How else would you envision this should work?
4 years later is there still no work around this? I never could understand the need such “nudge” when you have no direct control the amount, while recall previous commands with one button tap is much more useful…
