I have this imported brep (Purple on the left), that has been imported from Revit as a block and then exploded. The problem that I am facing, is that I am using these elements in grasshopper to align planes on the surfaces. But since the planes align with the isocurves, I would like to rebuild the brep to look like the one on the right (Grey brep).
Is there any native grasshopper component or plugin that does this?
@martinsiegrist solution works for this exact model. But if the geometry I am sent, is skewed in any way, maybe rotated on the z axis, the solution won’t work.
That’s why I am looing for a more sustainable solution like fixing the iso curves, so that it does not really matter how the geometry is rotated, I can always use the iso curves for alignment.
