Rebuild - Master surface
A “master surface” option in Rebuild similar to the “master curve” option would be very useful when rebuilding surfaces. I occasionally add knots to a surface, and would like to be able to rebuild other surfaces with the same arrangement including knot spacing.
Also, why is the “master curve” option only available in the command line version of Rebuild, -Rebuild? The master curve option could be included on the Rebuild panel similar to how using a starting surface is included on the Patch panel.
Hi David, I agree the master curve option is a very useful tool and ought to be in the dialog…
https://mcneel.myjetbrains.com/youtrack/issue/RH-43027
https://mcneel.myjetbrains.com/youtrack/issue/RH-43028
@pascal Another thought about a “master surface” option. Make the master surface option available in RebuildUV to enable rebuilding to match different surfaces in each direction. This would be particularly useful when a surface is in a corner. Even better would to have the option to match a master curve in each direction.
Hi David - I added your comments to the bug track item above.
thanks,
