RebuildUV - add Retrim option
Add a Retrim option to RebuildUV so that trimmed surfaces remain trimmed surfaces. Rebuild already has a Retrim option.
Got that, thanks.
RH-60490 RebuildUV: retrim option
RH-60490 is fixed in the latest WIP
Hello
I would like to quote one thing about this command, is there a way to not change the degree of surfaces with this command.
after rebuilduv. the degree becomes 3 in all situations
which is not desirable in most situations
if you can add the possibility to keep the original degree of the surface
thank you
fares
