Rebuild curves to master curve
Hello, I would like to learn what function of the Rebuild curves to master curve tool where it can be useful consists in?
Hello - the idea is that if you have multiple curves and one you like- it has the structure you want - you can impose that structure on all of the rebuilt curves, making them all compatible for say, a Loft surface.
Interesting function…
But only I don’t understand as this tool can be used for surfaces? :thinking:
2018-01-10_194529
There is currently only a “Master curve” option available in -Rebuild. A similar option is not available when rebuilding a surface.
Rebuild can be used with either a curve or surface by specifying the desired degree(s) and number(s) of control points.
Ok…
If function is available and for a surface - I think it it will be useful.
I previously requested a Select surface option be added to Rebuild Rebuild - Master surface Looks like current priority is “Wish”.
