Hi there,
I have a question concerning annotationstyles and their alignment.
I want to create polysurfaces out of a text and it’s working fine with TextEntity.CreatePolySurfaces Method.
The problem I am having is, that sometimes I need to change the dimstyle, as the Method needs a dimstyle.
When I have a text like this…
and I change it to this…
I need to realign the text.
What would be the best strategy to do that? Or am I missing an option that would make my life easier…
Thanks,
T.
HI @tobias.stoltmann , as far as aligning is concerned, you could use the plane property of TextEntity.
For example
TextEntity textEntity = new TextEntity();
Plane pl = Plane.WorldXY;
pl.Translate(pl.YAxis * -10);
textEntity.Plane = pl;
thanks @Darryl_Menezes.
But how will I determine the translation vector from the one plane to the other?
Ah, I got that, I guess.
E.g. I could get the bounding box and then get the relation inbetween those.
I will try and report.
Well, it depends on what you are using as inputs (or any criteria) for placing those texts.
@Darryl_Menezes
this is the solution I implementd:
is_horizontalmatch = target_style.TextHorizontalAlignment == entity.TextHorizontalAlignment
is_verticalmatch = target_style.TextVerticalAlignment == entity.TextVerticalAlignment
if is_horizontalmatch == False or is_verticalmatch == False:
#Match the existing text to font and height to receive the correct geometric data
entity.Font = target_style.Font
entity.TextHeight = target_style.TextHeight
entity_point = entity.GetBoundingBox(entity.Plane).Center
entity.DimensionStyleId = target_style.Id
future_center = entity.GetBoundingBox(entity.Plane).Center
vector = entity_point - future_center
plane = entity.Plane
plane.Translate(vector)
entity.Plane = plane
else:
Oh sorry i misunderstood your question. You could directly assign the TextVerticalAlignment, and TextHorizontalAlignment properties of your DimensionStyle to to your target alignment. And then you are anyways assigning the dimension style id to your text entity,
so entity.DImensionStyleId = targetstyle.Id should be enough
