Real time panel in grasshopper?
Hello all,
when i search from a list by text match i need to hit all time OK to execute the panel input and get the result… is there a way to get a result while tiping without execute …like in a search engine or auto complete in a editor.
Otherwise searching is really comberson if you dont know the object names.
I’ve made a little component that can help you achieve what you’re looking for:
As you can see you need to right-click on this component to edit the output text.
RealtimeTextBox.gha (8 KB)
Sourse Code:
using System;
using System.Collections.Generic;
using System.Windows.Forms;
using Grasshopper.Kernel;
using Rhino.Geometry;
namespace RealtimeTextBox
    public class RealtimeTextBoxComponent : GH_Component
        public string text;
        public RealtimeTextBoxComponent()
          : base("RealtimeTextBox", "RTB",
              "RealtimeTextBox",
              "Params", "Input")
        protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
        protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
            pManager.AddTextParameter("text", "text", "text", GH_ParamAccess.item);
        protected override void SolveInstance(IGH_DataAccess DA)
            DA.SetData(0, text);
        public override bool AppendMenuItems(ToolStripDropDown menu)
            Menu_AppendTextItem(menu, text, Menu_KeyDown, Menu_TextChanged, true);
            return true;
        private void Menu_TextChanged(object sender, string inputText)
            text = inputText;
            ExpireSolution(true);
        private void Menu_KeyDown(object sender, EventArgs e)
        protected override System.Drawing.Bitmap Icon
            get
                return Properties.Resources.Icon;
        public override Guid ComponentGuid
            get { return new Guid("472d3975-b91a-42ea-91cc-22bde76ab832"); }
RealtimeTextBox.zip (28.6 KB)
Perfekt…i Love it
I tried your component and it was compiled for another version but thankfully you provided the hole project i could compile it for another version AND WOOPS HER IT IS…so nice to search in a rhino file for geometry objects and get a real time preview of the object and name…Thanks again
Could you please upload the gha file here?
Well done @Mahdiyar!, any chance to support for Rhino 5, I tested it and doesn’t appear.
@flokart what is the main difference of your compile version?
Here I recompiled it for Rhino 5.14:
RealtimeTextBox(Rhino5.14).gha (8 KB)
thanks @Mahdiyar, just for curiosity what is that component?
@ThomasE I’m pretty sure it’s this: False start toggle maybe not the ladybug one though…
Edit:
Hmm maybe it’s this one https://bitbucket.org/andheum/falsestarttoggle
+1 for this!
Is there any chance we use this component with a panel. I mean we type the word in a panel and search for it. It saves some clicks. Thanks Manoochehr
