Is it possible to have an answer to these two questions please?
I would like to know if it is possible to modify in real time a native revit geometry with GH. If I have a column for example, and I want to modify it in particular without touching the others.
Why does join mesh generate geometries so messy in revit?
Native Revit geometry is generated from the Type and Instance property data. GH does not generate the geometry but you can interactively control the property values to generate different geometries. There is also DirectShape elements that can being any geometry into Revit and categorize correctly but they don’t have the interactivity that we are used to with each Revit element type.
Revit uses an old geometry engine and bringing geometry into Revit efficiently is an ongoing challenge. RIR gets improved with each version.
