I need to import some excel data into the canvas.
I’ve tried to use Read file, TT toolbox, Ghowl and Ghexcel components. I also tried to change the extension but it doesn’t work.
I didn’t find any realted topic on this and really need to solve.
Many thanks for any suggestion.
do you have excel installed? if not, most of the xls importers don`t work
try this https://www.food4rhino.com/app/npoiexcel
Actually I have Openoffice calc.
This component works fine.
Thank you so much!
I have the same problem and wasn’t able to resolve it.
@jacopo.cattaruzzi does it work for you now?
It works fine for me. I am using TT Toolbox and I think you might need to connect the file path from panel to “File Path” component as the attachment.
I had a similar problem with the ‘1. Solution exception:Object reference not set to an instance of an object.’ error.
Turns out I just had to change the name of my sheet to ‘Sheet_1’ and it worked.
