I have a problem with the PlugIn TT Toolbox and its Excel Reader component.A project that has been running (successfully) for a while, always with the same Excel file, now generates an error message. I wanted to subsequently add an additional spreadsheet to my Excel file and read it in via the Excel Reader as before. So I added the spreadsheet to Excel, saved it normally, as I did a few times before. But all of a sudden the following error message appears:
Troubleshooting I tried myself:
The spreadsheet is named correctly, I re-read the path, re-linked the component, reset the Read Input again and saved the Excel file under a different path. None of this helped.
Also interesting: The old spreadsheets are still recognized, only all new content since a certain date is not recognized. As if Grasshopper still has an old file linked. As you can see in the picture, only the new component with the “Test” spreadsheet does not work. The old component where I use the worksheet “Table5” still works.
Thank you very much for your help, I am looking forward to your suggestions!
Best regards,
Andreas
