Dear Grasshopper community,
This has been one of the things that truly drives me crazy in Grasshopper. I made a triangle and divided it into triangles through Lunch Box. The surfaces that comes out seem to have different orientation without an order. Even if I explode the surfaces and re-build them again, they still follow the same order (Probably because the points are built in different orders in each triangle). I even tried to using my own lines built in grasshopper without any plugins to divide the triangle but the same issue keeps coming up.
So I realized that the only solution is to actually re-orient all the surfaces or flip them to the same direction even if they are not ordered correctly as long as I give them a Vector or Direction to follow.
Any clues how to do that ?
Question.3dm (72.4 KB)
Trin Orientation.gh (40.4 KB)
