Re-order the points following another guide order
Hi all,
I want to re order the points of the smaller curves following the order of the points of the biggest one, I have tried Curve CP but it doesnt work.
Anyone can give me suggestions?
Thanks!!!
upload a file!
what do you have, need to change?
But I’m guessing you’re going to say that your geometry is more complex than rectangles.
order.gh (10.4 KB)
so you´re happy with your solution?
congratulations
yes I wanna do with the more complex geometries (NURBS curves in 3D, follow another bigger or smaller curve), but for the starting I would try with the simple problem: the 2D rectangles follow a bigger rectangle. Thanks for your help, I will try to solve.
Hi, I dont know why the result has 3 items
order_edit.gh (23.3 KB)
CLOSEST POINT node. Count = 1.
