Randomly place referenced objects on points
sorry to bother you again but none of the other posts helped me and I am turning mad here…
I am trying to randomly place referenced objects on points.
The objects vary between 70 and 300 curves and I am not able to jitter them properly without constantly repeating the last branch/object…
I tried “jitter” for the points and “repeat data” for the objects but it just wont work.
I’ll attach the .gh file.
Hope you can help me.
Kind regards and a happy christmas time,
Fabian
K8_Fassade_Question.gh (289.3 KB)
Would that work for you ? There are some point groups where the same object repeats, some others where it doesn’t.
K8_Fassade_Question.gh (283.7 KB)
Hello Teddy,
thank you very much! This will totaly work.
Would it be possible to not have the same numbers twice in a row in the “random” component?
So that I would allways have three different objects on the point groups.
Yes, a bit more tree management but it’s possible.
I ended up using Jitter instead of Random.
K8_Fassade_Question.gh (291.1 KB)
Perfect!
Thanks again :slight_smile:
Little note for everyone having the same issue:
If you didn’t copy the whole file by teddy you have to right click on the “Tree Branch” component and disable maintain paths.
