I was very happy to be able to make hatches in sections in Rhino 8. But now I found that the hatch is changing after closing the file and reopening again.
original:
after reopening:
Is there a way to solve this?
Cheers, Henk
Hey Henk -
Does that consistently happen after reopening? Please post both the output of the Rhino SystemInfo command and a 3dm file that we can take a look at.
Hi Wim,
Thanks for answering.
I send you systeminfo and the file. Unfortunately the original file was to big to attach, so I took out some of extra info.
The point by now is that I am not able to reproduce the problem, although it happend twice today. This is quite annoying. I will come back to you as soon as I have more info.
kind regards, Henk
troubleshooting Brug 4 brugnaam.3dm (12.2 MB)
systemInfo 20241209.txt (2.6 KB)
Hi Henk -
Secondary graphics devices.
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
External USB display device with 8 adapter port(s)
- There are no monitors attached to this device!
This is likely to get in the way of things when using Rhino.
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 6-23-2023 (M-D-Y).
Apart from that, it’d be good to get those drivers updated. You can open the Rhino Notifications panel and follow the links to the NVIDIA download site.
Dear Wim,
Thanks for your reaction,
I deinstalled the whole Citrix-stuff because I am nog using it anymore, so I am quite surprised that it is still mentioned in the systeminfo. No idea where to delete this.
And you are right, the NVIDIAdriver is good to be updated.
kind regards, Henk
