Random on prompt
is it possible to have random values when a command asks you to enter numerical values?
example: when the pipe command asks for the radius (to be applied to several curves at the same time), type “random” at the prompt and have different random values for each curve in its radius?
thank you
If you want to pipe multiple curves with different radii, a script is the way to go.
