without a file, i can only describe a way to do it.
- bounding boxes around each tree
- create a list of random rotation values, one for each tree
- rotate the trees using those values around the centroid of the bounding boxes
ok…thnx i will try it ( i am new and i hope to learn) and i will post again…
Try @jaymezd method if you’re unable to achieve it. Next time post your script/ file. That will be more easy to help.
Cheers,
BVR
Check this out but bear with my tree model ha ha
Rotate in place BVR re.gh (915.2 KB)
Cheers,
BVR
thnx u bro…!but what if have more trees e.g i didnt count how many copies i have…so how i will be able to enter the exact gene count in the gene pool??is there a way to do it with a number slider??
thnx!!
cheers
Use list length to count the number of items and a random component with a domain of 0 to 360 to generate a uniqe rotation angle for each tree. Change the seed value until you like the result.
thnx…!i will try it…how i insert the random component with a domain??
sorry bro i am new to all this…and struggling…
Just upload your Gh script with Internalized Data of trees this will be quite easy to all while helping.
This what Internalise Data means next time upload file without error.
I suggest you to first learns gh bascis from here:
https://www.modelab.is/grasshopper-primer
Read this too:
rotate in place.gh (6.4 KB)
File with range.
thnx and sorry for the mess…so thnx again…
