Make a list of random values, with as many values as branches there are in the first list.
“Match Tree” or “Unflatten” the random values, making a list which has the same branching as the first one, just with one value per branch
Rotate the panels in the first tree with the random values. Even though the list lengths are different, Grasshopper will stretch the shorter list to match.
Hi J porral,
Thank you for your response. I’m not sure I understod your way to do it. I have posted the gh file below.
I’m grateful if you could have a look at it.
I tried to follow your recipie. It looks like the tree structure is OK, but it still produce too many panels when rotated. See attachment.
Any thoughts where I’m doing something wrong?
Thank you fror your reply.
I’m not sure I understood what you meant. How can I input a list of seeds?
I want the values from one list to merge into the other list. And the end result should be the same amount of panels rotated, and not multiple as it is now.
