As the title sais…
Hi Jasper -
Please provide your SystemInfo
data.
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15002, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Commercial, build 2024-01-09
License details: Cloud Zoo
Apple macOS Version 14.1 (Build 23B74) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookAir10,1
Language: en
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1
DELL U2715H (2560 x 1440 @ 60.00Hz)
Color LCD (2560 x 1440 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/PlugIns/import_modelio_macos.rhp “Model IO Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp “Import glTF” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp “ShrinkWrap” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp “Export glTF” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_USD.rhp “Export USD” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_E57.rhp “E57 Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/MPlane.rhp “MPlane” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Squish.rhp “Squish” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_M.rhp “Import_M” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_X.rhp “X Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STL.rhp “STL Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STL.rhp “STL Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_Points.rhp “Points Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X.rhp “X Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_Points.rhp “Points Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 8.3.24009.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.3.24009.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.3.24009.15002
Hi Jasper -
That looks like that should work. Could you post or upload the file so that we can try to reproduce that here?
