I believe I found a new bug in Rhino 8 Grasshopper with something that was previously working in beta (and prior versions)
In some cases (such as the file attached) the Boundary Surfaces component fails to yield a result despite it having a closed polyline. (A)
Oddly, if I explode the polyline in question, sort its vertices by the polyline itself via Sort Along Curve, and then construct a new polyline from said sorted vertices, the Boundary Surfaces component works as expected. (C)
Alternatively, If I use the cull duplicates component on the Polyline control points and then create a polyline from the culled vertices, that also works. (B)
I thought perhaps the segments being joined were facing opposite directions, causing some kind of glitch but I used the dir command in Rhino to ensure they are all running counter-clockwise and still am having the same issue.
I have a feeling the underlying issue is related to what it considers a “closed curve” and if the rhino polyline has the extra vertex, it considers it open technically. This is evidenced when you use the Control points component on a rectangle or square, you always get a 5th control point at the seam location. Just my guess…
Thanks for your help!
