Quickest Way to Array Object Along Curve?
Hi there, using grasshopper what is the quickest way to array a 3d object modelled in rhino along a curve? So that the object is always perpendicular to the curve.
Thanks,
Adam
Perp frames and Orient…
Thanks, do you know how I get the initial plane of the 3d object to reorient?
Is your 3D object oriented on the origin?
Thank you! : )
Ok next question - how to ensure the frames are vertical? I guess this would mean the planes are no longer perpendicular though. Perhaps I need a different approach for that?
There’s a component called ‘Horizontal Frames’ which might be easier to use than modifying the perp frames…
Align Planes component might help
Thank you!!! Super helpful and I appreciate the quick response. Have a great week.
