Quick Curve Blend Not Working
Can someone try to see if Quick Blend Curve is working for them? I select the two ends of the curves but noting happens.
the command _Blend ?
it’s working for me with build 515.
is it not working for you on a particular set of curves or does it not work in any situation?
Don’t know what the problem was. It didn’t work on a set of curve i had, discarded them and started again and all seems fine now?
