Questions about BESO for beam
How to realize this “GroupIds” function?How does this component enable optimization of component batches?
If you input a groupid, this will remove these elements as a group: please refer to 3.6.9: BESO for Beams - Karamba3D 2.2.0
Dear Matthew:
Thank’s for your replying.
I want to optimize the support of the floor slab in groups.As shown in the figure I have set up 30 groups of ‘V’ columns ,and I want to achieve a simultaneous increase or decrease in the V-columns by ‘BESO for beam’ component.
I have set the groups id as shown below, but the final optimization result is still having separate diagonal columns.I don’t know if I have set the group id wrongly.I am appreciated it if you tell me how to set the parameters correctly.
Group Id question.gh (34.6 KB)
Hi, the BESO removes elements from your model. If you want to size them, then use the CrossSectionOptimisation tool
Dear Matthew:
I would like to implement such a function—— During the iteration of “BESO for beam”, each “V” column (2 columns) is deleted or added as a whole, instead of adding or deleting a single diagonal column.
How should I set the parameters(groups id) to realize this function?
