i am trying to script Orient 1D in grasshopper base on the points i have setup. simply just point by point like the image below. i wonder if there is similar way to do it in grasshopper?
Thanks Martin,
I have simplfied the block object, and the distance of ever 2 point are slightly different and the upper roll of points and the lower roll points are in different XY coordinate as well
I’m not at my computer. I don’t see whether the distances between the points are equal or not.
You can try to create a polyline with the target points, explode the polyline and flow the rectangle from the line between the two points to the polyline segments…
